Mods Please delete Feeler 1989 Notch roller
Hey guys. I know that some of you from SVTsnake know my situation, but for those who don't, my 1989 Notch has an engine issue indicated by oil pressure problems leading me to contemplate swapping in a new motor or selling as a roller.
I figured I would test the waters of the roller market .
Asking $3,000 as it sits now, but like the title says it is a feeler so make an offer. I will pull the engine, or you can have it as is (I guess it isn't a true roller then lol).
most of the good mods are suspension parts. The exhaust sounded good when it was running
3:73s
disc brakes 5lug conversion,
Steeda ball joints
Steeda bump steer
Steeda adjustable caster camber plates
8 way adjustable shocks and struts
Eibach pro springs and sway bars
Tubular control arms upper and lower
poly bushings
All new brakes calipers pads rotors and braided line master
BBK headers
BBK hpipe
Flow master exhaust
BBK Cold air kit
70mm Mass air meter
MSD Cap rotor coil
NEW Ford Racing wires
Autolite spark plugs
Walboro 255lph fuel pump
Newer interior carpet
Newer seats
Newer door panels with custom running pony and mustang on them
Newer headliner, package tray, sills, and all new weather stripping
New Heatercore last year
17" bullit wheels and tires
Clear headlights
65 MM throttle body
BBK Fuel pressure regulator,
hose kit from Ford Racing (blue)
GT40 upper and lower intakes
Here are some pics:
3:73s
Steeda ball joints
Steeda bump steer
poly bushings
BBK headers
BBK hpipe
Flow master exhaust
BBK Cold air kit
70mm Mass air meter
MSD Cap rotor coil
Newer seats
Clear headlights
65 MM throttle body
Here are some pics:
