Sorry I posted this problem in the Tech/Write Ups. Ineed to use this forum more. The problem I'm having is I get evap and catalyst not ready codes on obdII scanner. 02 sensors show ready. Last year inspection worked fine after a couple of miles, 02s, catalyst and evap. Since then I have installed cmcv delete plates, I had that system turned off in tune, along with that it shows secondary air pump off. I think these two are connected(cmcv and air pump), I'm not certain haven't had a chance to talk to tuner. Secondary air pump may have something to do with evap not ready?
Catalyst not ready: delete plates and Mafia installed, is too much air being moved through high flow cats that prevent 02s from doing a complete job
I have Kook lth and high flow cats.
For catalyst not ready, I'm thinking of having mid pipes made to include my oem cats and remove the high flow and install oem catted mid pipe. Even though it passed last years insp with high flow cats cmcv delete plates where not installed. I'm just about out of options.
The risk of running into a vehicle check point is getting closer each time I'm on the street. Option of taking my car off the street
I'm hoping someone out there has experienced if not he same but similar problem.
