You don't need a lip..... you need a hole....so drill the hole the proper size
and location, then go and get a steel spacer the proper diameter.....
then you have the lip for the idler pulley. Problem solved. But the
bracket does fit.....you just need to modify it slightly to work on
your appication........These are not problems, just minor issues
that need some fabrication to correct it.
