Fox body twin turbo setup. I built the kit to run on a 393ci windsor with Victor Jr heads. Twin On3 76mm turbos with .68 A/R exhaust housings. K&N airfilters, turbo blankets, Twin Xo2 46mm waste gates with braided lines, 50mm Tial BOV, braided oil feedlines and -10 Aeroquip blue return lines, 3" coldside with 4" thick core air to air intercooler. BBK shortys with v-bands, Hot side is fully v-banded, you will get about 2' of down pipe but no mufflers. Fast dual channel wide band. Holley 750 with Proform center, 4 corner idle, built using Hangar 18 mods, Extreme Velocity hat with 1" o-ringed spacer welded to it. Aeromotive 13202 regulator with braided -8 lines to the carb. Complete kit ready to bolt on and run. Must be used with turbular front suspension. Kit was built around a TeamZ tubular front suspension with solid motor mounts. $3500 or reasonable + shipping.
