On my 69 Coupe I am converting the E brake to a center trans tunnel set up. I already purchased the handle assembly & I am looking to see if anyone has a Fox body Mustang they are scrapping if you could cut out around the area where the E brake mounts to the tunnel including the bracket welded to the underside of the trans tunnel that the E brake cable runs through. Answer here or PM me with the cost. Thanks, Mike.
