This morning when I was leaving for work the stang was making some crazy noises up front. When I turned the wheel left and right I would get loud squeaking sounds. When I am driving and go over bumps it squeaks agian. It is mostly coming from the left front. Also @ 55 mph the steering wheel was shaking pretty bad. Like it had a serious case of Parkinsons Only does it @ 55-60 mph, anything below or above and it stops.
Should I be thinking ball joint/ tie rods? Steering rack?
I have never had these symptoms on any vehicle. Mind you that I am at 105k miles with all original suspension.
Help!!!
Help!!!
