Go and get a price from a garage that will do the install & dyno tune. Cams at AM are $729.99. Your first dyno tune at a shop will be $500.00 minimum. Most will charge more, check realspeeds websight for pricing, Valve springs $300.00. I didn't know you had hand SCT handheld so -$379.00. Install will be more then $500.00, more like $1K, min. My '00 needed cam gears, I dont know if yours does $289.00. Miscellaneous parts like oil, oil filter and gaskets. It adds up pretty quick.
I had a quote and was told $3.5K-$4K from a reputable shop who is on this sight. He talked me into getting SC for $1K more then a set of cams. I got over 100hp from SC, you'll get 30-35hp depending on other mods from cams.
If you could swap out cams and get dyno tune for less then $2K everyone would do it.
