Do I need a new fuel sending unit and if so where can I find one for an 86 GT...reason I think i need one is because my gauge reads empty even though I fill it up, however when the car is off the gauge is way below the E and when it starts the gauge moves right below the E..this at least tells me the gauge is not broken. I recently purchased the car and the prior owner, well was a bad owner. Any info will help it gets annoying not knowing.
I checked the connection/plug that is located right by the rear bumper right next to the tank on the passenger side and those connector were covered in some nasty stuff..cleaned it out and that's when the gauge moved ever so slightly...anything else I should try before assuming is the FSU.
thanks
thanks
