Well ive been trying to aquire new flywheel bolts. Not having much luck in exactly what i want. I ended up stripping about 4 threads in 1 crank hole out of the 6 holes due to me not realizing the big difference in depths of flywheel and felx plate bolts. I found a set of ARP bolts that measure 1'' in length, my current ones measure about 1/2'' to 3/4'' at most. So i am going to take it easy with that one hole, but i did order the set. For anyone needing to know the size is 7/16-20. Ordered from summit so hopefully these will be here by this Saturday when i expect to progress more. Hoping for the best out of this situation.
I also looked into other fasteners at hiawatha fasteners. I saw grades of flywheel bolts ranging from grade 8-10. But the head on a normal bolt is not as large in diameter as a true flywheel bolt which had me worried. Hiawatha fasteners didnt stock anything over grade 8 but could order them.
The dealer bolts measure just over .9'' in length, but will need to be ordered and cost almost $7 a piece.
Yesterday was beautiful here, out crusing in the Wrangler made me really wish the car was done and i was cruising in it!
