Hey all,
98 Mustang gt - BBK intake/catted x/ slp loudmouth I's
NO Check engine light - autozone said no codes
Threw Lucus injector cleaner in it
Monday got up and car is cutting out/missing under load... All gears, can neutral rev fine, runs fine at constant speed - slight miss at idle but it always has had that.... Is slightly worse when running higher gears/lower RPM's like 5th at 50 it will shutter pretty bad...
I have tried: :smash:
Cleaned MAF
Installed E3 plugs in DEC - sswapped for old ones got worse - E3's back in
Air filter is good
New Fuel filter is in
Checked coil packs (pulled the wires off all are arching about the same)
dumped water on it (I know it's a no no) - all seemed good no extra miss at idle
Today: I need to - ideas?
Seems to be less cutting out more like hiccuping now
Cleaned MAF
Air filter is good
