360 HP 370 Ft Lbs AFR 12.1 at WOT
331 Stroker, AFR 185 62cc, Flat Tops 0 deck height, Air Gap knock off ported to heads, Comp Cam 274HR, Quick Fuel Carb 650Q, 1in Spacer, LT 1 5/8 Hpipe w/ flows
Quick Fuel carbs Rock... didnt even need to change jets just air bleeds to lean it out a bit. Wild thing is 30* 33* and 36* total timing showed minimal change, literaly +/- 1hp. My setup is maxxed out. If i want anymore HP i need to up the exhaust or change the cam. Any ideas on that??? BTW see the consistancy on the runs... Over all very happy!
