1993 mustang notchback, 351w,c4 8.8 275/60... tons of new parts, make offer ... NEW AJE K member and control arms, new rack, new rotors and brack ,rebuilt calipers. New front tires, new struts and coil overs, bump steer kit, S&w frame conncetors, drive shalft loop, rear lower upr links, upper edelbrock links and bushings, tb box kits, Comp rear cover over kit, TEN eng rear axles and long wheel studs, axle bearings and seals, pinion seal, trick flow rear end cover, rear brakes, cut the drums, new 15 x 10 welds with new 275/60 15 hoosiers , new trick flow tranny pan, all new -8an fitting and line from sumped stock tank to motor, new battery, new elec fan, new rad hoses, new super Victor jr intake, rebuilt hardcaor racing carb 830 cfm, new alt 110 volt, valve covers , motor and tranny were built and in the car when i got the car, had a fire ring issues, engine guy said it was from sitting, head fixed " have pic's of all of this, both before and after" cometic gaskest, arp studs were used when this passed winter. I was told its a 68 block .30 over , steel crank and H beam rods. I have never had t
he bottom end apart to confirm this, C4 manual valve body with rev pattern, 8" converter. I can go on and on for another page with new parts, I
nee
d to pay bills is the only reason for the sale. All the parts listed are new with in the last year. thanks
845- eight 2 five- two zero six five
