the belt needs to come from the smog pump eliminator pulley then go up over the water pump, then down to the left side of the crank pulley, the problem is there is no power steering pump so the water pump is spinning the wrong way, not sure but i think there is an eliminator kit for the power steering to correct this. Also the "cooling" lines going to the throttle body are actually "warming" lines for cold weather, they are to warm the cold are coming into the intake, since you live in florida you are okay without them unless you drive the car in freezing weather, plus colder intake air=more power
