Hi,
Did you remove your old (original)valve cover?You should be able to match the new bolts to the old ones as you remove them. Is this a stock valve cover or an aftermarket? I have an all original unrestored 66 sprint 6 cylinder coupe in my garage I can take a look at if it will help you out? Do you happen to have a photo of the bolts in question?
