Engine has an aftermarket BBK 78mm throttle body with plenum, 30lb. injectors, Comp cams 268 extreme cams, Comp cams valve springs, seats and new valve seals. The block is from a 98 stang with 50K miles. The heads are PI giving the motor 10:1 compression and the exhaust manifolds have been ported. Also included is an 04 Cobra mass air meter & SCT tuner with a $750.00 Dyno tune for this motor on it! Runs very strong!
The motorwork, seals, gaskets were done less than 6 months ago.
$2100.00 OBO
$2100.00 OBO
