I am listing my car the correct way with all the info I can remember. I know Im going to miss some things so feel free to ask.
Its a red 93 LX hatchback with a Bennet Racing 408. The body has about 70,000 miles and the motor has about 5 passes and 500 miles on it. The passes are not from me but the miles are. Everything else I list here has less then 1000 miles on it. The interior is mint and all ORIGINAL black tweed! Paint is in great shape with a few small nicks.
Benner Racing 408w, 351 Sportmans block, Scat forged crank, Scat 6200 H Beam rods, Ross pistons, main support, TFS stage 3 Highports, Custom Bennet cam, ported Victor EFI intake. 42lb injectors, 80mm TB, 90mm C&L MAF, 4in CAI, March polished pulley and bracket kit. Car is 70% tuned as of now via a PMS. I just did the EFI conversion over the winter and havent had time or good weather to finish it. I have original build sheets with detailed info for new owner.
TKO600 with Ram heavy duty clutch and billet aluminum flywheel, lakewood bellhousing, Ford Racing aluminum driveshaft, Ford Racing adj cable w/ firewall adj.
8.8 rear with Moser 31 spline fox length axles with North race cars caliper brakets, M2300k Cobra brake kit.
MSD Coil.
Msd programmable 2
Griffen alum radiator
Mark VIII fan
Smoked headlight (hids)
Florida 50 gauge panel w/ autometer phantom boost, water temp, oil pressure, speedo, tach, fuel level.
Innovate wideband o2 sensor.
Alpine radio.
10 point chromoly cage w/ window net by CJM chassis.
2- 5 point harnesses.
Full length subframe connectors.
Upper & lower torque box reinforcements.
Tubular k member and arms
Wolfe double adj UCA.
Maximum Motorsports LCA
Team Z Caster camber plates.
Bumpsteer kit.
Front Strange 10 way adj coilovers.
Rear 10 way adj shocks with progressive rate springs.
Eibach front & rear sway bars.
A1000 fuel pump.
-10 feed and return fuel lines.
Aeromotive boost ref regulator.
Glenns performance Sleeper tank.
Taylor batt box.
Optima red battery.
130 amp alt.
17in Bullet wheels
Mt 275 drag radials
Only reason for selling is I bought a New Mustang and want to see this car go to a new home where it will get used and not just sit in my garage. This is a great car at a great price! $12,000 OBO. Sorry for the crappy pics. Really must see in person! Call or text me for a faster response at 718-866-7186. I can send pics of anything you like.
MSD Coil.
Msd programmable 2
Mark VIII fan
Alpine radio.
Bumpsteer kit.
A1000 fuel pump.
Taylor batt box.
Optima red battery.
130 amp alt.
17in Bullet wheels
Mt 275 drag radials
