1991 mustang lx hatchback, car will need to be put back together, have no time to get in garage between work and family stuff also need something more of a daily. Details below and don't low ball don't need the money!!!
351 Windsor bored .030 with forged pistons Trickflow twisted wedge heads fresh port and polish(Frankie Ford),new springs,comp cam,roller rockers, black powder coated Victor Jr. intake, new 850 Holley hp series. It has an MSD Digital6,csr electric water pump.mishimoto aluminum radiator. There is a new steel driveshaft(for auto) and an 8.8 rear with spool, c- clip eliminators and fresh 4.10 gears which was narrowed 1 inch per side, also have a tko500 to go with the car was an auto but was planning to do the swap only thing needed is a flywheel and clutch pedal. UPR chromoly K-member and Strange 10-way adjustable struts with coil overs in the front and Strange 10-way adjustable shocks in the rear. Double adjustable chromoly upper and lower rear control arms. There is an 8 pt mild steel cage, frame rail connectors, new rug,also new rug for hatch area still in box. new fuel system with Aeromotive Street pump. Weld Draglites 15x4's up front and 15x10's in the rear with street tires also have an extra set of rims with slicks. The car has a 2.5" Cervini fiberglass hood. The car has an NX Gemini Kit, This motor has never been sprayed. The solenoids, bracket and bottle warmer are still in the car but the plate and bottle have been removed. All of the nitrous parts come with the car. I have all new gaskets, plugs wires and other stuff to put car back together. Car ran good was just freshen everything up body's in good shape few things here and there nothing major it's a 10footer, Im sure Im forgetting some stuff also open to trades need something a little more daily let me know what you got. Thanks.
What you will need off the top of my head to finish fly wheel, clutch pedal setup and drive shaft. Few pics below will add more tomorrow or email me at downset4130@aol.com and I'll send thanks asking 5500 can add a lil cash for the right trade.
Located in queens ny
http://s222.photobucket.com/user/lo...1?page=1&_suid=139878120794805608179841772223
