The T5 transmission also has 150K miles and is totally stock. When cold this transmission will grind into 3rd gear but shift perfect in all other gears. When warmed up this transmission shifts perfect in all gears. So the synchros should be checked before installation. Removed to replace with a T5Z transmission. Comes with trans only, no shifter or bellhousing. $150 takes the transmission.
