My father has 19" zennetti chrome wheels on his truck. The other day I noticed the tire was losing air, so I checked it. I found that it was leaking from the rim itself, not the bead. I circled where it is leaking, can it be fixed?
having a hard time with this one....is the rim cracked at that location you circled? is it leaking where the spoke meets the lip of the wheel. try to give me alittle more info.
it can be fixed wielded on both sides or u can try to only wield it from the inside first and see how it works out .
An idea identify on the inside of the rim where the crack is get a small piece of weldable metal shape it to fir the curve of the rim and then wield the piece in place.
