taillights work fine but i have no brakelights, checked all fuses and relays all working fine,changed brakelight switch under pedal and still nothing...HELP!!!!:nono:
Was the fuse blown or intact? If it was blown and you replace it and blew again, the you have a short. I had an exposed brake wire once, and every time I pressed the brake pedal it touched the wire shortening the circuit, blowing the fuse.
Check the contacts in the bulb sockets ,they get really corroded . next get your self a test light have somone step on the brakes check for power at the sockets, if you have no power there check for power at the brake light switch going in and out. work from the bulb sockets foward and isolate the problem.
