Well, now the car has 2 more problems, for one i screwed up the first 3 plug wires on the left looking at the front, and the ignition module that controls the soleniod won,t work. i turn the car over and it doesn't get spark until i turn the key back to off. only does it every once in a while but it's getting worse. so can anyone post a pic of the distributor plug wire numbers so ican figure out where the three i got mixed up go. and any suggestions on how or if i can bypass that ignition module. attached are a couple pics to describe what i mean
This First is the ignition module or whatever is is next to the battery and connects to the solenoid and the starter.
The second shows the first three plug wires i retardedly took out and fucked up, and need to know what the wire numbers are on the distributor and the firing order so i can fix it.
