To pop the trim from the front and rear windows you'll need a tool like this...
To take the drip moulding off, open the door and look down towards where the mirror is.  About an inch up from the end of the rail, there is a little bracket with a screw.  Take that out and carefully pull the rail off as it's held on with a type of glue/sealant.  Finally, to remove the trim around the windows, roll them down, pull the channel weatherstriping off and carefully work the trim off...it is held on by pressure, be careful as in the corner of the small trim around the window the vertical piece has a little nub that slides into the horizontal piece so you have to work them off slowly together to avoid wrecking them.
