[FONT=Arial, Helvetica, sans-serif]Installation              of Oil Pressure and Water Temperature Gauges[/FONT]
[/FONT]
            [/FONT]
Why is this                  necessary?   The 2000 Mustang oil pressure sending unit                  is just an on/off switch.  When the pressure reaches 6 psi,                  the switch goes on and the oil pressure gauge goes from zero to                  mid-scale.   The water temperature gauge indicates temperature                  changes up to about 90 degrees C (194 degrees F), which is mid-scale,                  but the needle will not move any higher until/unless some extremely                  high water temperature is reached.   Neither of these stock                  gauges gives true readings or any warning of developing problems.                   Aftermarket (real) gauges do that. [/FONT]
                      [/FONT]
                                  [FONT=Arial, Helvetica, sans-serif] Autometer #3337                    2-1/16" electric water temperature gauge, with 1/8" NPT sending                    unit and 3/8" & 1/2" NPT adapters ($39.95 - Summit Racing)
                  [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] Autometer #3327                    2-1/16" electric oil pressure gauge, with 1/8" NPT sending unit                    and 1/4" NPT adapter ($49.95 - Summit Racing) [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] Autometer #10003                    94-00 Mustang 2-1/16" Dual Instrument Cluster ($59.95 - Summit                    Racing).  Painted with DupliColor Vinyl & Fabric "Medium                    Gray", which is a close match to my "Medium graphite" interior                    trim.   The gauges press fit into the cluster.   The                    two long mounting screws in the back of each gauge are not used,                    and should be cut off.   There is a rubber skirt at the                    bottom of the stock instrument cluster.   It can be re-used                    when you install the new one. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif]When you pull the                    Rear Window Defrost Control Switch out of the dash, it exposes                    wires with all the power feeds needed for this installation.
                  [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] I spliced wires                    into the following lines:
                  [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Pin 3 - "Power                      Feed (Hot in Run)" - provides +12V for the gauges. [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Pin 4 - "Switch                      Ground" - provides a ground the lights (the gauges will be                      grounded with a wire to the engine block). [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Pin 5 - "Switch                      Illumination" - provides +0 to +12V for the lights (dimmer                      circuit). [/FONT]
Caution:                     There are two black wires.   The smaller one is the "switch                    ground" wire. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] The gauge pod installed.                    I had to slightly enlarge the holes for the Light switch and                    the Rear Window Defroster switch.   Otherwise it fit fine.                      The wiring worked as planned.  The gauge lights                    dim along with the dash lights. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] Rather than cut                    or modify the stock firewall grommet, I pried it aside and inserted                    a 3" piece of 5/8" radiator hose along side the grommet, in                    the same opening.   Then the wire loom containing three                    wires (two sender wires and a ground wire) was run through it.                      I will seal this opening with silicon sealer when the                    gauge installation is completed. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] The stock oil pressure                    sending unit is in an almost inaccessible spot, so I installed                    the Autometer sending unit in the the #8 O-ring plugged hole                    at the base of the oil filter.  The sending unit is mounted                    at a right angle so that it clears the front sway bar.                      Three fittings were used to mount the sender: (1) a #8 O-ring                    plug to 1/4" NPT adapter (2) a 1/4" NPT Ell, and (3) a 1/4"                    NPT to 1/8" NPT adapter. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] You can get the                    #8 O-ring to 1/4" NPT adapter (drawn above) from a firm that                    sells hydraulic fittings.   If they don't understand what                    you want, try asking for a 1/2" male o-ring port to 1/4" female                    pipe thread adapter.   The other two fittings are standard                    hardware store items. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] The stock water                    temp sending unit is also in a tight spot, right under the drivers                    side fuel rail.   I've heard that putting in a T connector                    to run two temp sending units can cause problems (low readings)                    because the sending units are no longer directly in the flow                    of hot water.  So I decided to leave the stock unit alone,                    and mount the Autometer water temp sending unit on the bypass                    hose to the right.  That's where the water temp sending                    unit is mounted on DOHC Cobra engines. [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] The water temp sending                    unit, ready for installation.  A 90 degree brass fitting                    has been drilled and tapped for the 1/4" NPT sending unit.                     Since there will be no metal-to-metal contact with the engine,                    I also drilled and tapped a ground connection (10-32 machine                    screw & nut).
                  [/FONT]
                    [/FONT]                                   [FONT=Arial, Helvetica, sans-serif] Sender installed                    in the bypass hose.  The new curved hose is from Pep Boys,                    #80400 CS. [/FONT]
                 [FONT=Arial, Helvetica, sans-serif] The total cost of                    this installation was about $175   That included: gauges                    = $90, gauge bezel = $60, wire, connectors, hose, pipe fittings,                    wire loom = $25 [/FONT]
Update - May                    2005:   I recently pulled the intakes off my car                    to port/polish them, and used that occasion to drill and tap                    the lower intake for a 3/8" to 1/4" NPT brass adapter to mount                    the Autometer temperature sending unit.   (shown at A in                    the photo above)   To do that you need a 9/16" drill and                    a 3/8" NPT tap.   On a 99-00 car you can drill into the                    pad just above the thermostat (as shown above).   On 01-04                    cars, you have your choice of that pad or the pad where the                    stock sender used to be located.   (In 2001 the stock temperature                    sending unit was moved to a cylinder head).   [/FONT]
                 [FONT=Arial, Helvetica, sans-serif] Another approach                    used by some people is to screw the temperature sending unit                    into the cooling system vent tube   (shown at B above).                      It seems to work O.K. in that location, but you have                    to take it out every time you drain/fill/vent your cooling system,                      and if all the air is not bled from the cooling system,                    there is a possibility that the sending unit will be surrounded                    by air rather than hot coolant.   I chose to go with a                    permanent installation in the lower intake, where I know the                    sending unit will come in direct contact with the coolant. [/FONT]
