Ford Racing Ford Racing Performance Part of the Week: 351ci Aluminum Block.
Introducing the new Ford Racing Z351 aluminum
engine block, designed for builders who demand light weight and
industry leading strength.
The new Ford Racing Z351 block casting process
was computer modeled for optimum liquid aluminum flow and proper gating
ensures a dense casting with minimal porosity. The 356-T6 aluminum
block casting is precision machined to the tightest tolerances and
includes billet steel caps to ensure long life and engine durability.
Ideal for street and drag race use, the Z351 is
the basis of Ford Racing's Aluminum 427 crate engine and 2000hp race
engines like John Urist's SSO Mustang.
Part Name: 351 C.I. Aluminum Block.
Part Number: M-6010-Z351.
For more info, visit http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=4221
High strength aluminum block, 356-T6 grade aluminum
4-bolt, steel billet main caps, splayed on 2,3 and 4
3.99" bore as delivered, cast iron sleeves capable of 4.125”
Weighs approximately 124 lbs.
9.5" deck height, uses standard 351 timing chain, oil pump and hardware
2.75" crankshaft main journal diameter, 2.9415-2.9425” finished journal diameter
2.2032" - 2.2052" cam journal diameter uses cam bearings, part number M-6261-J351/R351
Maximum stroke 4.250"
Wet Sump Oiling System
