This truck is going through an entire restoration. Everything will be new and will be done the way Ford should have built it. Im setting the truck up for heavy duty towing, not off roading. (although there will be some BFG All Terrain Tires on it) It will be able to tow roughly 10,000 lbs when completed.
Front Suspension
4 Monroe Reflex shocks
F350 Coil Springs
Air Bag Helpers
Rear Suspension
Custom Length F350 Leaf Springs
Monroe Load adjusting Coil Overs
Air Bag Helpers
Frame
Boxed in vital weak areas
1 3/4" Front and rear sway bar
100% Polyurethane Bushings through entire truck
Class IV Hitch with trailer brake
Electrical
Custom wiring harness front to back
Upgraded stereo
130amp Alternator
Auto Meter Gauges
Engine
351w stroked to 408 cubes
AFR 185 Heads
Forged dish pistons
Transmission
Ford ZF 5 speed out of 99 F350
Axles
3.73 Gears front and back
Trac Loc 8.8 Rear End
Interior
Custom Diamond Plate fabricated.
Cutting the old body off the frame
Sawzall, Torch, and Air Chisel
Rusty Frame
My Buddies Grinding the frame
Frame Painted With Chassis Saver
Picked Up a Rust Free body tub from Texas
This is what $2200 worth of parts looks like
Custom made F350 Leaf springs (They can handle over 2500# a piece)
Bead Blasting is messy
Front Suspension Mocked Up
Front Dana 44 Axle housing after paint
Installed the new U Joints in the new spindles
Steering Knuckle
								Front Suspension
F350 Coil Springs
Air Bag Helpers
Rear Suspension
Air Bag Helpers
Frame
Electrical
Upgraded stereo
130amp Alternator
Auto Meter Gauges
Engine
AFR 185 Heads
Forged dish pistons
Transmission
Axles
Interior
	Rusty Frame
	Steering Knuckle
