Ford Racing produced just fifty Boss 302R race cars for 2012, so getting your hands on one is a little more difficult than putting in an order at your local Ford dealership. Those interested in acquiring a Boss 302R of their own are in luck, though as an example – number 16 of the 50 produced – is currently up for sale on eBay.
The turn-key race car is priced at $130,000, just $4,995 less than it cost to originally cost to buy from Ford Racing, but the seller describes the car as almost brand new and in factory condition having competed in just two races in Grand-Am’s Continental Tire Sports Car Challenge. The Boss 302R has been fitted with the new 2013 bodywork but comes with the 2012 body panels as well as two extra seats of wheels.
You can check out the listing on eBay here or view the car’s full specs and a photo gallery below.
Powertrain:
- Ford Racing 5.0 liter V8 four valves/cyl
- Ford Racing TTC close ratio 6 speed transmission
- 3.55:1 gear ratio
- 8.8-in Torsen T2R limited-slip differential
- Ford Racing Clutch
- Seam-welded Ford steel unibody
- Integrated safety cage
- Structural performance: over 20,000lb-ft/degree (torsional)
- Ride-height adjustable Koni inverted coil-over struts, compression and rebound adjustable dampers
- Adjustable caster/camber plate
- Urethane Bushings
- Adjustable anti-roll bar
- Multimatic 3 link with panhard bar
- Koni coil-over dampers; ride-height, compression and rebound adjustable
- Urethane Bushings
- Front – Brembo, 4 piston calipers
- Rear – Ford, stock
- ABS – Ford, recalibrated production
- BBS 18 x 10″ front / rear
- ATL 22-gallon, custom dual dry break fuel cell
- Walbro 255 L/H fuel pumps- SK fuel pressure regulator
- Recaro position adjustable racing seat
- Sparco quick release steeringwheel
- Sabelt 6 point safety harness, HANS compatible
- Center mount console switches
- AIM digital dash system- data logging and display
- SPA cable activated extinguisher
