SOLD!!!
Boston Acoustics GT4100 (Used 2 weeks switched out for 5-channel amp) $200.00
GT Reference Series 4-Channel Amplifier
RMS Power Rating(14.4V):
Red LED power badge and orange protect indicator
4/3/2 channel operation
Adjustable mounting feet (mounting feet move along rails to allow the easiest installation)
Fully computer-controlled diagnostics system (continuously monitors amplifier in case of thermal overload, short circuits, or over voltage)
Q-Tune™ technology combines sophisticated crossover adjustments with Q-Control settings to seamlessly transition rear bass to the front sound stage
Heavy duty fan cooled aluminum alloy heatsink
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (20-250 Hz, 12 dB/octave)
Variable low-pass filter (50-350 Hz, 12 or 24 dB/octave)
Signal Voltage Input (200mV-8V)
Frequency response: 10-95,000 Hz
Dimensions: 22-1/4"L x 9"W x 2-3/8"H
4-gauge power and ground wiring is required for installation
- 4 ohms: 100 watts x 4 chan.
- 2 ohms: 150 watts x 4 chan.
- 1 ohm: 225 watts x 4 chan.
- Bridged, 4 ohms: 300 watts x 2 chan.
- Bridged, 2 ohms: 450 watts x 2 chan.
- 4 ohms: 85 watts x 2 chan.
