Unfortunately due to the fact that my Cobra has 6 piston front and 4 piston rear calipers with 13" & 12" rotors I'm basically stuck with 18" rims.
So I have another set of 18x10 Chrome Saleens on the way and I want to get some REAL Drag Radials for the rear (which have to double as Track Tires should I decide to have some fun on the 1320).
I currently have Brand New 305/35/18 Nitto NT555R's but they suck monkey ass for traction so I'll probably sell them while they're new with my current 18x10 Chrome Saleens or just keep them as my winter tires & rims.
I've had luck with 15" Mickey Thompson ET Street Drag Radials before and will most likely go with them in 18" when I save a few more bucks. I know the 18" would be as good so going taller is a must for them to hook and of course wider. So here's the question...
I have a 8.8 SRA Rear (3.73 Gears, Eaton Posi, Moser 31 Spline Axles) that's 3/4" shorter on each side than the orig irc was. So they used 1" billet aluminum spacers behind the rear rims (for flush offset).
So that tells me I can go another 1-1/2" wider and remove the spacer providing I have enough room on the inside, which I think I do. (when the snow melts I'll get under and measure)
So do you think in my case I could fit 345/35/18 ???
They would be 1.1 " Taller and 1.57" Wider than what I have now.
I have my doubts about being able to go 1.1" taller but I guess when you cut that in half it should fit
All indications I have so far are there is plenty of room inside
Yes the inside of my rim is bent, I never knew it until I saw the pic's I took and it doesnt effect anything but it was another reason I bought a new set of rims
amof it actually looks like I can keep the spacer and let the rubber come out another 3/4" on each side. This pic is looking straight down the wheel well to the floor (you cant even see the tire as it is now)
Opinions, options, suggestions ???
