HERE IS THE LIST OF WHAT THIS MOTOR HAS, EVERYTHING IS BRAND NEW NEVER USED..(TOP TO BOTTOM)... PRICE IS $4500 NOT GOING LOWER SO DONT EVEN BOTHER..
750 CFM STREET DEMON CARB POLYMER BOWL.
MSD PRO BILLET DISTRIBUTOR, MSD WIRES, MSD DIGITAL 6AL IGNITION BOX, MSD BLASTER COIL..
TALL PROFORM FORD COBRA STAMPED STEEL VALVE COVERS, BLACK CRINKLE RED RECESSED EMBLEMS...
FEL-PRO VALVE COVER GASKETS
SCORPION TALL ROCKERS 1.62f EXHAUST 1.72f INTAKE
LUNATI 10310461 HYDRAULIC FLAT TAPPED CAMSHAFT RPM RANGE 2000-6000 LIFT .512/.512 dur @.050 230/230 LSA/IAC 109/105
EDELBROCK RPM AIR GAP INTAKE MANIFOLD
FEL-PRO INTAKE MANIFOLD GASKET
ALUMINUM EDELBROCK E STREET CYLINDER HEADS 170 WITH 2.02
ARP HEAD BOLTS
COMETIC HEAD GASKET
92 5.0 GT BLOCK PAINTED WITH EASTWOOD CERAMIC PAINT (FORD BLUE)
FORD SMALL BLOCK 4340 FORGED ROTATING ASSEMBLY STD WEIGHT FORGED CRANK, I BEAMS W 3/8 WAV LOC THRU BOLTS, I BEAM W 3/8 CAP SCREWS, H BEAMS W 7/16 CAP SCREWS, FORGED DOME PISTONS, ROD BEARINGS ,MAIN BEARINGS AND RINGS, EXTERNAL BALANCER.
TIMING COVER WITH DIPTUBE HOLE AND FUEL PUMP MOUNT..
EDELBROCK TIMING CHAIN
SUMMIT RACING MECHANICAL FUEL PUMP
MELLING HIGH VOLUME OIL PUMP
TRICK FLOW CRANK GIRDLE WITH ARP BOLTS
CANTON 7 QUART OIL PAN
FEL-PRO OIL PAN GASKET
ARP OIL PAN BOLTS
ILL THROW IN A ENGINE STAND WITH THE MOTOR...
For another $200 ill throw in the gauges and polyurethane mounts...
ARP HEAD BOLTS
COMETIC HEAD GASKET
ARP OIL PAN BOLTS
