it is a 306 built by extreme racing engines
Block:
xxx high nickel block bored .030"
srp forged pistons
eagle forged h-beam rods
eagle cast crank
Heads:
World Products windsor jr with Harland sharp roller rockers
Summit Racing Part Number WRL-053030-1
Cylinder Head Style Assembled
Cylinder Head Material Cast iron
Cylinder Head Finish Natural
Combustion Chamber Volume (cc) 58
CNC-Machined Combustion Chamber No
Intake Runner Volume (cc) 180cc
CNC-Machined Intake Runner No
CNC-Machined Exhaust Runner No
Intake Port Location Standard
Exhaust Port Shape Square
Exhaust Port Location Standard
Intake Valves Included Yes
Intake Valve Diameter (in) 1.940 in.
Exhaust Valves Included Yes
Exhaust Valve Diameter (in) 1.600 in.
Valve Springs Included Yes
Maximum Valve Lift (in) 0.560 in.
Outside Diameter of Outer Spring (in) 1.250 in.
Camshaft:
Custom for a bronco
will get specs when I find card
also have Motorsport B or E cam to go with it if you want it $100
No mustang intakes but it does have a edelbrock truck intake on it if interested $400
with a good intake this should make 350hp with a different cam
it also has an edelbrock high flow water pump
engine only needs valve covers, intake, mustang oil pan to be put in your stang
$2800 for long block
$100 for motorsport cam
$400 for edelbrock performer efi truck intake
pm me or call 516-852-0837
thanks for looking
Chris
Block:
srp forged pistons
eagle cast crank
Heads:
Camshaft:
Custom for a bronco
thanks for looking
Chris
