I decided to switch to a powerglide. I love C-4's because they are so fast but I am at the limit to where they will hold anymore power
I have 2 killer transmissions.
1) PA Supercomp with $1,000 worth of upgrades to include:
C-5 case
Modified, rollerized and welded front drum
Rollerized #9 bearing
Extra clutches for strength
Welded Kevlar Band for 2nd gear
Rollerized 3 pinion planetary
Super hard input shaft (broke the PA one so we upgraded)
Internal trans brake with reverse manual valve body
Billet servo
Deep aluminum pan tapped for temp sender
Modified pump to improve oiling
Currently being freshened and should be done by 6-24-10
$1,800 OBO
*No Bellhousing*
2) Dynamic Mighty Might M2
Hughes C-4 SFI scattershield
JW SFI 157 tooth Ultra Bell
C-5 case
Hardened input shaft
External Pro-tree brake with reverse manual valve body
Modified stock servo
Currently in the car
$1,900 OBO
Will have freshened for $200
Ulitimate Converter Concepts "Renegade" Nitrous Convertor
List price for this convertor is over $1,400
Has 25 passes on it
4,200 stall, 10.5" bolt pattern. Built like no other and strong!!
As is $650 obo
Cut opened, cleaned, re-welded & balanced add $200
TCT Nitrous Convertor
4,200 stall, 11 7/16 bolt pattern
List price is $1,200
Fresh and ready to go
$550 obo
Steel Nitrous Driveshaft
1350 u joints
Strange Billet trans yoke
Over $900 to built new
Built for c-4 in a fox. (No spacer required)
You will need your own 1350 pinion yoke for 8.8 or 9"
$500 OBO
modified crossmember for c-4 in a fox
B&M Pro ratched sfifter with cable
$100 both (will only sell if transmissions sell)
Call Doug with any questions.
(716) 450-1827
or email djvanstrom@eha.us.com
C-5 case
Billet servo
$1,800 OBO
*No Bellhousing*
C-5 case
$1,900 OBO
Has 25 passes on it
As is $650 obo
$550 obo
1350 u joints
$500 OBO
(716) 450-1827
