1985 mustang gt fresh sassy grassy green paint 5" extended cowl hood new winshield dash out of a 1990 mustang quarter windows out of a 90 mustang 8 point cage new carpet optima red top battery convo pro wheels m/t slicks much more very sharp car
ENGINE
331ci rblock
Ross flat top pistons 12/1 compression
Eagle 4340 crank
Eagle 4340 rods
Hellfire rings
Trickflow highport heads
Jessel shaft rockers
Msd crank trigger set up
Induction solutions set up victor jr with edelbrock victor series fogger
Custom ground nitrous solid roller cam
Comp solid roller lifters
Kooks stainless headders
3" flowmaster exhaust
T6061 aircraft grade aluminum front and mid plate
Flowed barry grant silverclaw 1200cfm carb / motor was built for a ton of nitrous can take a 500 hit noproblem currently has 300hp pills in it
NITROUS SYSTEM
Edelbrock victor series fogger
E2 nozzles good for a 500 hit
Purge kit
Pressure gauge
Bottle heater
Set on a 300 hit
Digisets for nitrous timing
TRANSMISSION
Dynamic c4 full roller with trans break warranted for life best one they offer
Ptc 6000 stall nitrous converter
Dennys nitrous drive shaft
Hurst pistol grip shifter with button
Big trans cooler with fan
8an braided tdanny lines
blow threw bell/scatter shield
COOLING
Csr electric water pump
New 4 core aluminum radiator
2 black magic fans with aluminum shroud
FRONT SUSPENSION
Upr tubular kmember
Upr tubular control arms
Strange 10 way adjustable struts
Coil over kit
Caster/camber kit
New calipers, rotors, pads, bearings, hoses,tierods, everything is new
Flaming river manuak rack and shaft
Upr manual brake conversion
REAR SUSPENSION
Upr pro rear suspension adjustable upper and lower control arms
4cylinder springs
REAR END
Sos built 8.8 braced
Strange 35 spline axles
Mosher spool
Auburn pro 4.11 gears
Sperical bushings
Rear girdle
FUEL SYSTEM
Mallory 250 pump with return
Mallory comp fuel filter
Sumped new tank
-10 fuel line
MISC
Has msd 6al
Msd coil
Has alpine speakers c
Flip out tv deck
So much more car will do low 9s high 8s on the nitrous fresh motor has minimal run time just had it freshend up nasty street car just want something different looking for 14,000 obo or trade every part off thr drivetrain is best of the best you cant buil the engine for what im asking call/txt 315-5722186
ENGINE
331ci rblock
Eagle 4340 crank
Eagle 4340 rods
Hellfire rings
NITROUS SYSTEM
Purge kit
Pressure gauge
Bottle heater
Set on a 300 hit
TRANSMISSION
COOLING
FRONT SUSPENSION
Upr tubular kmember
Coil over kit
Caster/camber kit
REAR SUSPENSION
4cylinder springs
REAR END
Mosher spool
Sperical bushings
Rear girdle
FUEL SYSTEM
Sumped new tank
-10 fuel line
MISC
Has msd 6al
Msd coil
Flip out tv deck
