It is candy red out side black in side with rci seats has a 10 point cage in it. car has 80 k one it like 3k on motor. It is a 5 speed car with t-5 trans done over at huntington transmissions. Rear is still stock right now no leaks. new breaks all around (stock). Motor is a 302 stock block honed speed pro moly rings file fit clevite 77 main and rod bearings polished and shot peened stock crank stock rods factory forged pistons lunati 51014 cam 500 intake 510 exhaust lift 218 intake duration 226 exhaust edelbrock perfomer heads 1.90 intake valve 1.60 exhaust precision 3 angle valve job comp cams double springs chromoly retaners 10 degree locks motorsport 1.7 roller rockers performer rpm intake manifold
holley 750 double pumper msd distributer with custom timing curve cloyes timing chain canton 7 quart pan and pickup
arp head studs all the work done at mustang magic. All the car needs is a tune and gears in the rear all said a done the car should run a 11.00 on the 1/4. looking for $ 5500.oo OBO all so will trade for gen 1 lightning
