when i first got my car it revved and dropped the rpms rather quickly and now it wants to hang the rpms and very slowly drop down, and it only drops down when i stop any ideas???
the one connected to the throttle body that wraps around it is that pulley for the flap is dried out the wire holds it open even if your not holding the pedal
here are some photos of what i am taking about i think its the recoil spring that its called if its dried out it will tension on itself and not allow for the throttle body to reset
When you say dried out do you mean it needs lube or it was one of those self lubricating stylesIf it's a lubricating style what type lube would be used.
