the bolt pattern is the same. however, the front tires will rub at full lock. the rears will appear to be sunk in some(a 1-1.5" HUBCENTRIC wheel spacer will remedy this). also, the tires are taller. the speedo will be off at speed, getting worse as speed increases. mine read 65, actual was 71. when it read 73 i was doing just over 80.
