So I started the big transformation yesterday......... Here's a list of what's being done
1. Clean and Paint rear housing
2. Weld Tubes
3. 35 spline Strange Axles
4. C-Clip Eliminators
5. Strange Spool
6. Team Z Relocated Uppers
7. MM Extreme Duty Weight Jacker Lowers
8. Strange 10 way shocks
9. All New Bearings
10. Ratech solid Pinion Shim
11. New FRPP 3.73's
12. Clean up all rust and undercoat
13. ARP Ring gear bolts
14. Seasoned Stock Rear Springs
So I started this yesterday and as of 7pm tonight still not finished mgno:
Yesterday I got everything stripped out,tubes welded,housing cleaned down and the first coat of POR15 on it.
I know welding the tubes in the car is not the correct way so nobody has to point that out but when you are promised that you can borrow someones jig and that someone falls thru shit still has to get done!!! I did the good old 2 inch stitch weld on one side and then the same on the other as to not distort the tubes to bad. It's worked on many other of my car's over the years so I am sure it will work again lol.
Done
Now you see the ends
Now you don't lol
all cleaned up and the first coat of POR15 on!!!!
Pictures of the good shit lol
Good stuff installed!!!!!!!
Some shots of the fresh under coat
The Raetech Solid shim (Replaces a Crush collar)
ARP Ring bolts
And the big boys installed!!!!!!
First time I have used a solid pinion shim and all in all it's nice to know its all set up and if the pinion seal ever goes bad all I have to do is take the pinion nut off change the seal and the re torque the nut to a 125 ft lbs. It did take me a little while to get the shimming correct with the solid piece and pinion depth I played around for about an hour changing stuff but got a good pattern and good back lash at .011
Tomorrow Ill put the cover back on get the ride height adjusted,pinion angle set, Sway bar painted and reinstalled, and the anti moan brackets cleaned up and painted.
This not having a weekend thing is really starting to bother me lol.
2. Weld Tubes
5. Strange Spool
9. All New Bearings
11. New FRPP 3.73's
Done
Now you don't lol
ARP Ring bolts
