From the MOMs Site:
New Rules for 2011
The Entry Level Classes:
Street – slight changes (allowed to win sequential championships)
Street Ltd – formally Drag Radial Limited- slight changes
Street Extreme- See rule layout
The Big Boy Classes:
DOT- formerly Drag Radial
N/A-no changes
P/A:-no changes
Entry Level Class Rules:
Entry level classes are based "on your honor" that you are running the equipment as defined by the MOMS Racing staff. MOMS Racing reserves the right to bump a car from any class, at ANY time in the name of fair and even competition.
1. Street-Tired:
306 CID limit. Factory 5.0, 4.6, 4.0 block, or any stock Mustang engine available appropriate after 79. Motor must be period correct. (ie. Fox Mustang will only be allowed a 302 based motor.) No power adders or stroker motors allowed. Bolt-on cars with mild engine modifications ONLY. Full factory interior, no bare floor pans showing, must be covered in carpet, rear seat delete kit is acceptable. Current registration and inspection. (no dealer plates) Mufflers mandatory. No Mini-tubbed cars. 3100 pounds minimum with driver.
Regular Street tires ONLY! Front and rear tires must be D.O.T. approved. (No drag radials, cheater slicks, dirt track, shaved or special compound tires allowed) All manufacturer's lettering and identification, plus the appropriate rating must be clearly visible to be deemed a valid street tire.
2. Street Limited:
Front and rear tires must be D.O.T. approved, All manufacturer's lettering and identification, plus the appropriate rating must be clearly visible to be deemed a valid D.O.T. tire. bias ply are not allowed in this class. NO CHEATER SLICKS.
3. Street Extreme:
Factory 5.0, 4.6, 4.0 block, or any stock Mustang engine available appropriate after 79. Motor must be period correct. (ie. Fox Mustang will only be allowed a 302 based motor.) Only one power adder or Stroker motor (not both) No after market blocks. No 2 stage nitrous or fogger systems. Limited to only one Fuel and one nitrous solenoid. No Twin turbos. Single small turbos limited to 70 mm. No “J” Trim or bigger blowers. No “F” series blowers. No cog or “V” belt drives. Serpentine ONLY. No Air to water inter-coolers. Full factory interior. No bare floor pans showing, must be covered in carpet, rear seat delete kit is acceptable. Current registration and inspection. (no dealer plates) Mufflers are mandatory. No Mini-tubbed cars. 3100 pounds minimum with driver.
Regular Street tires and DOT Drag Radials ONLY! (15 & 16" Drag radials are limited to a 275 max width. 17" and larger any size is OK, no limits for regular Street tires) Front and rear tires must be D.O.T. approved. Bias ply are not allowed in this class.(No cheater slicks allowed) All manufacturer's lettering and identification, plus the appropriate rating must be clearly visible to be deemed a valid street tire
4. F-150 Lightnings:
While no longer a separate class, they are still welcome to race with MOMS! SBF (351 or 5.4-based) only. Mufflers are required but whatever you want to do after that is up to you!. Your class will be determined by your tire choice and/or power adder selected.
The Big Boy Class Rules:
Big Boy classes are based "on your honor" that you are running the equipment as defined by the MOMS Racing staff. MOMS Racing reserves the right to bump a car from any class, at ANY time in the name of fair and even competition.
1. DOT :
SBF (302/351 or 4.6/5.4 based) only. Anything goes as long as the stock wheel wells are intact and a stock-style suspension is used. , Mini-tubs are approved as long as a stock type suspension is still used.
Any D.O.T Tire is OK. Front and rear tires must be D.O.T. approved and bias ply are OK too. Mufflers are mandatory. 3000 pounds minimum with driver. All manufacturer's lettering and identification, plus the appropriate rating must be clearly visible to be deemed a valid D.O.T. tire
2. Naturally Aspirated:
SBF (302/351 or 4.6/5.4 based) only. Slicks and mufflers required. Any engine modifications are allowed, but no power adders. 2900 pounds minimum with driver.
3. Power Adder:
SBF (302/351 or 4.6/5.4 based) only. Slicks, mufflers, power adders required… whatever you want after that, just make it sick & safe! No complete tube cars please, back-half cars OK. 2900 pounds minimum with driver.
Existing rule to be eliminated: Street Class Champion is limited to one consecutive year. Since this is really a beginner class and we want to promote fairness as well as provide a way to rise to the ranks. After winning a Street title the Champion will automatically be promoted into the Drag Radial Limited class the following season. If they get a different car the following season (after one season off) then they will be allowed to compete in Street if they wish provided they meet the rest of the rules for that class.
This rule will no longer apply and the Champion of any class will reign as such until another competitor is able to take the title away.
______________________________________
Schedule Dates
Sun. May 22
Fri. June 17
Fri, July 15 SS!
Fri. Aug. 19
Sun. Sept 11
Place:
EMPIRE DRAGWAY!
Hope to see you there.
New Rules for 2011
N/A-no changes
P/A:-no changes
1. Street-Tired:
2. Street Limited:
3. Street Extreme:
1. DOT :
3. Power Adder:
Schedule Dates
Sun. May 22
Fri. June 17
Fri, July 15 SS!
Fri. Aug. 19
Sun. Sept 11
Place:
EMPIRE DRAGWAY!
