So I researched this a lot last year, but I guess I was wrong. To answer questions off the bat, here is what I'm running:
-4.6 block with stock internals
-Vortech V2 S-trim
-Vortech Fuel pump 255lph
-3.25 pulley
-Intercooled
+ all other bolts ons and whatnot.
Currently putting down 371rwhp/368rwtq @ 10psi
I thought through my research that I would be able to conservatively put down around 425rwhp with stock internals... please correct me if I am wrong here. I thought I had read that through a lot of threads and stuff, but maybe I was just naive and didn't think about internals? :smash:
Anyway, I called the performance shop I use and they said they don't suggest putting anymore power on the block because its not safe. What I wanted to do was upgrade my fuel pumps (possibly adding the Boost-a-pump) and switch to a smaller pulley to hopefully make some more boost/more power. When I tuned it originally at MM, Joe said the fuel pump wasn't strong enough to make more power with the pulley I had.
What do you guys think? Thanks for any help/advice you can provide
-Vortech V2 S-trim
-3.25 pulley
-Intercooled
:smash:
with no motor issues.
