Not much more progress to date but did find the cause of the blowout, well the initial one anyways (continued driving/state of denial of a blown head gasket not recommended).
After disassembly, it was noticed that there was quite a bit of oil/black crap on the intake and exhaust valves and intake runner on the #4 cylinder (same cylinder with blown gasket section). On further inspection, the intake valve seal was pulled off the guide (thanks 96irishcobra for the find). So when I swapped out the AFM hi-rev springs last year, I did note the ID of the inner spring was a tad smaller than the originals (like by 0.01-0.02 if I recall correctly). So at some point in the season, the spring grabbed and yanked the seal off the guide of the intake valve and let lots of oil into the cylinder. I'm guessing the added oil in the chamber taking up volume is like raising the static compression ratio to a point that lowered the threshold for detonation/preignition.
So I'm just specing out parts to buy to put everything back together including valve seals with reduced OD's. The positives are that all of the bores/cylinders/valves look to be in great shape (almost as good as when it was new) and all the surfaces were checked to be flat. Not bad for 6 years at "elevated" power levels. I wonder what the bearings look like.
But most importantly, its good to know that the cause is found and that it was not from too aggressive of a tune (to think I was going to back down on the timing this year, LOL). Will post more pics of the rebuild once I get it restarted.
-Chris
