$500
15X8 Draglites in great shape 5 lug 4.5/4.75 in. Bolt Circle, 5.5 in. Backspace with centercaps
M/T ET Streets 26X10.5 (only few passes)
Inner Tubes (still in box, never got a chance to replace)
Wheel screws
The short answer is yes.
The offset on the 03/04 cobra wheels I believe is 26mm and has a backspacing of just over 6 inches. The offset is similar on these draglites but they're 8 inch wide instead of 9 thus the 0.5inch less backspacing. The outer edge of the draglites will be inboard by about 0.5inch relative to the cobra's wheels but with the same size tire, the tire will be in the same position. I always thought the cobra's wheels could come out further out for a meaner look and if that's the look you want, simply add a spacer . . .that's what I do
