Found this.
When you have erratic spark I 'd look for a cracked magnet in the magnetic trigger, if it's a Ford style (MSD replacement) magnetic trigger and you have installed the magnet upside down it does the same thing, or if the trigger wires are reversed.
For the coil, I found this. It is the MSD HVC-2.
When the mad scientists at MSD were creating this 7-series ignition coil they pulled all of the good stuff out of their Pro-mag 44 coil and stuffed it into this one. The HVC-2 Coil produces 48,000 volts at a stout 2-amps with only .016 ohms of primary resistance! It utilizes an iron U-Core design with a segmented bobbin molded from Rynite and wound specifically for incredible voltage capabilities, lightning quick rise time and lengthy spark duration. The Rynite housing features far spaced brass primary terminals and a well protected secondary tower for increased spark isolation. The housing is completely potted with an epoxy compound for vibration resistance with mounts.
For use with MSD 7-Series Ignitions.
Hope this helps, I will keep looking for a solution.
