Im tossing around the idea of selling my black 93, since I'm stuck with my 89 drag car. I've had it a long time.I dont use it. It's solid, runs/drives perfect and could use minor work(2 small bubbles on trunk and a drivers seat)--$7250 asking 1993 Mustang GT
Owned sine 1994 Black/Black mint interior( all except drivers seat) Sunroof 5 speed-I have owned this garage kept car since I graduated H.S. The undercarriage is spotless. The paint is ok but original. Looks nice after a good wax. Car reads 130k on body.100k were from a merchandising route I drove for 5 years. 1/4 windows and trim are mint-sill trim and roof trim are excellent. The sunroof needs weather stripping but is also good(no leaks when it is out)
It runs perfect and is quick. I brought it to the track 1 time and ran a 12.40 @ 110mph with 26” slicks 1.78 60 ft.
Pony Rims
2" lowering kit
OEM Saleen wing
2 ½ inch cowl hood
ENGINE- Stock 302, Trick Flow Track Heat stage 2 heads
Scorpion 1.6 rollers rockers
F-303 camshaft
Milondon 7qt oil pan
Cold air intake/with cone filter
75mm professional Products throttle body
75mm Pro Flow mass air
30 lb Motorsport injectors
Trick Flow Track Heat intake
1” plenum spacer
Trick Flow valve covers(tall)
Complete polished pulley set
All brackets are billet(ac delete, power steering, alternator)
9mm motorsport wires
Mallory coil
MSD 6al
Tremec 3550 Transmission with pro 5.0 power stick
SVO aluminum driveshaft
BBK long tube headers, matching BBK x pipe
Flow Master American Thunder mufflers
Drive shaft safety loop
Sub frame connectors with triangle supports-clean perfect painted welds
Monster Tach
Electric Fuel pressure gauge
Aeromotive regulator
255 lph weldon fuel pump
390 rear with Auburn mini spool
Rear Girdle
Pony Rims
2" lowering kit
OEM Saleen wing
2 ½ inch cowl hood
F-303 camshaft
1” plenum spacer
Mallory coil
MSD 6al
Monster Tach
Rear Girdle
