PLEASE CALL CELL: 212-433-0471
Don't check my email that often
I don’t have pics of all of this.
All parts are as close to new as possible, nothing is junk.
WHEELS / BRAKES:
Built 8.8 Rear: 5 LUG, 4:10:1 Ford Motorsport gears, Eaton Center section, Moser 31 spline C-Clip Axles, Moser C-Clip Eliminators, Trick Flow Aluminum Girdle Cover, 3" Moser Studs, North Race Car Brackets (so you can run disc Cobra Brakes), Brand New 12" Cobra Cross Drilled & slotted Rotors, Brand new pads, Cobra Calipers, Cobra Brake Lines, Southside Upper Control Arms, HPM Megabite Lower Control Arms - $1000
(this is the best of the best) (Less than 100 miles on this set up)
Cobra 13” Front Brake SetUp – 94-95 Spindles – Brand New Cross Drilled / Slotted Rotors, Brand new pads, Cobra Calipers (with COBRA written on them), new caliper pins and lines, Brand New 94-95 cobra brake booster with 93 Cobra Master Cylinder (1” inch bore” with Maximum Motorsports 3/2 conversions and adjustable proportioning valve - $750 (Less than 100 miles on this set up)
Modified E-Brake Handle to work with 5 lug conversion, with center adjustable cable and the correct e-brake cables to work for a fox body with disc brakes - $150
Wheels: Black with Polished Lip Deep Dish Bullet Wheels - 17x9 (front) with 245/45/ZR17 tires
17x10.5 (rear) with Mickey Thompson Drag Radials 275/45/17 - ALL BRAND NEW TIRES, BRAND NEW WHEELS - $800 ((Less than 100 miles on this set up))
SUSPENSION:
KYB Shocks – 2 struts, 2 rear shocks, 2 quad shocks – ( About 400 miles, if that on them) - $200
KONI Quad Shocks for an 8.8 (Use a 10.5 rim and 275 tire with these) Very thin - $ 150
Eibach Pro Kit Springs (black) - (400 miles) - $150
Stock Fox Body Front Lower control arms with Brand New Ball Joints - $70
BRAND NEW – Steering rack and pinion (SVT) Quick Ratio with brand new Tie Rods - $100
DRIVETRAIN:
5 speed Conversion – Aftermarket T5 with Bell-housing, Clutch, Clutch Fork, Pressure Plate, Pro-5.0 Shifter, Adjustable Clutch Cable, Pedals, Aftermarket Quadrant, Transmission Cross-member and mount - $750
Ford Motorsport Aluminum Driveshaft - $175
ENGINE:
TFS TWISTED WEDGE HEADS – 2.02 Valve, O-Ringed, with TFS push rods, 1.7 Studded Roller rockers, Ford Motorsport lifters, Ford Motorsport Double roller timing chain, Cam Thrust Plate & Lunati Cam, Lifter Valley Hold Down Plate, All ARP Head bolts are included - $ 1350
TFS “R” Intake, (75mm TB Opening) w/ Tall Valve Covers ( Gorgeous Black Powder Coat ) , with 1 inch spacer and all ARP lower Intake bolts, and hardware for the upper intake, with all bolts, All new gaskets for the upper & lower intake and valve covers included, also an Edelbrock Polished 75mm Throttle Body & EGR Spacer - $550
C&L 80mm Mass Air Meter (calibrated for 42lb Injectors) with New Air Filter & Ford Motorsport (green) 42lb injectors with fuel rails & fuel pressure regulator - $300
MSD 6AL with Quick Connect Wiring Harness & MSD Coil & New MSD Ignition Coil Wires - $250
Griffen 4 Core Aluminum Radiator, with Radiator catch can, with the best Electric fan on the market blows about 4000 cfm+ ( 2 speed fan ) with Permal Cool Fan Controller . Blows the most CFM of any fan out there - $200
A/C Delete Bracket - $50
High Flow Water Pump - $ 30
Brand New Timing Chain Cover with Bolts - $50
Long Tube Headers with O2 Sensors, & MAC Pro Chamber 2.5” with bolts - $150
MAC 2.5 Catback with 3.5” Chrome adjustable rolled Tips (Gorgeous catback) never in the rain - $ 275
Injectors: 8 (new) Deka 60lb High Impedence Injectors (needed for Supercharged Cars) - $275
Vortech V1 S Trim (Loud One) Polished Kit: 3.33 pulley, head-unit, brackets, tensioner, Crank Pulley, Belt, Inlet pipe, Bypass valve, Anderson Powerpipe, Oil Feed line and fittings, Oil Drain Line, Raditator Hoses, FMU All clamps and hose fittings and bolts - $1850 FULL KIT JUSTY BOLT IT ON AND GO
Stock Distributor - $50 (Excellent Condition)
Ask about Front Accessories
FUEL SYSTEM:
Brand new fuel tank, with brand new fuel level senor, Brand New 255lph In-tank Fuel Pump with all new gaskets with Brand New Vortex T-Rex IN-line Fuel Pump with wiring harness - $350
Exterior:
Cervini’s Stormin Norman 2.5” Hood (bolt on with Latch and Bolts) Billet Aluminum Hood Pins included - $250
MINT LX Front Bumper with molded Cobra Grill Insert w/ Chrome Horse with Head light support and Brand New Clear Headlights with New headlight seals - $300 (just bolt it on) Painted Black Pearl.
MINT Fenders with Cobra Emblems $ 100 (pair)
MINT LX Doors, everything works. Windows go up and down perfectly - $ 200 for the pair
Hatch Back with Cobra Wing - $150
Cobra Taillights - $150
LX rear Bumper - $100
Not sure if someone needs a Mint radiator support or Front Clip
INTERIOR:
03 Mustang Charcoal Leather Front Seats with Pony with Fox Body Seat Tracks & Reupholstered Rear Hatchback Charcoal Leather Seats to match the front – MINT !!!!!! - $ 600
Black Molded Carpet with Mass Backing to eliminate Road Noise with New Black Hatch Carpet – Excellent Condition - $150 for Both
Excellent Conditon Door Panels – Amazingly Clean
I have a Full Interior Grey Dash and Center Console – MINT
WHEELS / BRAKES:
SUSPENSION:
DRIVETRAIN:
ENGINE:
FUEL SYSTEM:
Exterior:
INTERIOR:
