This is a 100% complete ready to run NOVI 1000 supercharger kit. I installed this on my cousin's 89 GT and I also did the tuning on the car. It has a slightly smaller pulley which is around 9lbs on the stock motor. This setup on a DEAD STOCK motor with 175k miles ran 12.48@112!!! This was with the 19lbers and FMU! The NOVI 1000 has the 8 rib pulley setup like an S-Trim or NOVI 2000 along with the thicker bracket of the NOVI 2000. This kit is no longer available and the replacement has 6 rib and thinner bracket. This is VERY strong supercharger and nicely built kit. It has the Bosch bypass and nice aluminum discharge pipe. The injectors have less than 500 miles on them, they are FRPP 42lbers. The meter is an 80mm C&L. I myself tuned this car and it has a custom Diablosport CMR chip that runs a perfect 14.6-14.7 A/F at cruise and idle and mid 11's at WOT. Timing is conservative and very safe. This motor and car runs HARD and has 175k miles, over 10k with the sc. I have videos and it is all on the car still. All you need is a 255lph in tank pump!!
Asking $2000 for everything--
42lb injectors
80mm C&L maf
AFM 4" powerpipe
80mm MAF
WILL sell for less without the injectors and MAF and will substitute a 73mm MAF and FMU. This is the way the car was when it ran 12.48@112
42lb injectors
80mm C&L maf
AFM 4" powerpipe
80mm MAF
