I posted about my alarm system a few weeks ago and finally got around to take all of it out. Well, I'm finding that the box was ran into a lot of places. I can't even tell what who makes the damn alarm.
This is the box here.
This is where it was located.
This connector here goes into the right side and connects into another wire that runs along the top of the dash into the left side of the dash.
This wire at the top of the dash is where that connector went. The wiring here goes back down to the left side kick panel. Does anyone know if this wire has anything to do with the alarm, or if it was there from the stock harness?
This wire here goes from the alarm horn, and back through the firewall.
This positive side for the battery has another wire running off of it to what I believe is the amp that's underneath the seat. I don't know much about the amp stuff but does this seem right to you?
I haven't done any cutting so everything can be replaced if I can't figure out how to get rid of the "whole" alarm system. Reason I'm doing all this is because anytime I disconnect the battery, the alarm prevents the car from starting.
So any ideas on how to get rid of it, or does every wire that came from the alarm box have to go? Thanks.
