Well not yet but 99% of it is ordered. I figured I start a new thread instead of extending my planning thread. Some things have changed from the plan but not much. The budget goes pretty quick when you start spending it.
Here's what I ordered ...
MMR 600 shortblock w/
-- MMR side bolts
-- ARP main studs
-- MMR street/race oil pump
-- 2V piston notches
On3 70mm forward facing turbo kit
UPR tubular K-frame w/coil overs
-- 12"/200# springs
KYB front struts
Maximum Motorsports CC plates
Spec stage 3 clutch
Kurgan Motorsports 340lph fuel pump
Pro-M Slot style MAF
Siemens Deka 60# injectors
Innovate MTX-L wideband A/F gauge kit
Auto-meter boost/vac gauge
I have everything in except the turbo kit and the shortblock. Turbo should be here in a couple weeks and MMR estimates a 4-5 week assembly time. That should put delivery time around the beginning of March. I'm not planning on cams but I couldn't see getting a shortblock without the piston notches.
The main thing I have to wait for is MOTHER NATURE to turn the heat back up.:smash:
-- MMR side bolts
-- ARP main studs
-- 12"/200# springs
KYB front struts
Spec stage 3 clutch
