As the title states I need the section of the trans tunnel where the E-brake bolts to & the cable goes through the floor. I need the piece that is spot welded under the tunnel that the cable clips to. The E-brake handle I am using is from a 87-93 Mustang. I am adding the trans tunnel E-brake to my 69 Coupe & need these pieces if anyone is parting out a Fox body Mustang.
TIA, Mike.
TIA, Mike.
