This is an excellent product hands down and George at MGW is patient and open to any quiestions. The install instructions were very precise and accurate. The only problem is a little rattle noise that can be eliminated if a small amount of the supplied Dyna-mat is used on the billet mounting rod were it slides into the shifter base and, some hot air can come in through the center console if all the insulation (plus some more) is not put back on thoroughly. Once all that is done you get a shifter tailored to your style, not only is the throw adjustable but the height of the shifter is adjustable also. This is the only choice if you plan on swapping out shifters.
