Yaaa i dont see ne reason why i wouldn't...gonna feel like a complete different car....did u ever run less boost? i cant wait for that KB whine but people say it isnt real noticeable untill your running like 12lbs?
My first mustang was a 02 GT with a KB 2.1 on it that i installed my self, i had it custom tuned down at Tillman Speed in Aston PA and they did a great job, car made 410RWHP and 424TQ on Dynojet...hit 12psi on graph and timing was a safe 16* cause both the 12 psi was to high on stock block and my fuel pumps where running out of duty cycle, could of easily hit 450whp if i had changed the pumps out but not good for the stock block...The chip KB provides is good enough to get you going for a while, to give you an idea i had the KB chip with a 10psi pulley on a Mustang Dyno base line pull she made 346RWHP and 363TQ no tuning!! You will be really happy with the end results this car will do compared to a stock GT...GL with install...
Well if you plan to have it custom tuned then highly recommend getting 42lb injectors just to be safe than sorry...the 36lb injectors are good for 400 give or take....
yahh i might look into that be4 i go thru with the install but id see myself flirting with more than 400hp. i'm not trying 2 push the motor higher than that i cant really afford to blow it up after all this money i just spent between the blower, gauges and install.
