With my new set-up, the transmission can not handle the power to race, the transmission has roughly 1000 miles on it with 4 passes on the track, it is a TKO500 with aluminum fly wheel, 50oz balance, aftermarket bell housing, shifter, Spec stage 3 clutch, aluminum drive shaft and 3.73 gears.
Everything is going in one lot, I do not want to separate, bought new you are looking at $2700 just for the transmission, you would be almost $4000 for everything, this is being put up as a quick sale, everything is in the car if you want to inspect if first before it is taken out by my builder at his shop, once it is taken out, you can pick it up at his shop.
My asking price for everything is $1800.00, again, that's for the transmission, complete clutch package, drive shaft and rear end gears.
